Re: Error 62 - Serial Port Overrun Error
Hi Naveen,
I too have got the same error code 62. (Serial Port Overrun Error). Did you solved the issue. can you suggest the solution.
(2,663 Views)
Hi kanimozhi,
I guess you have a different problem than Naveen 12 years ago…
Can you attach your VI and explain the conditions when that error 62 occurs?
(2,656 Views)
