Re: How do I log data to the cRIO-9022's 2g storage space using lab view 9?
I am very new to the cRIO.
May I kindly request you to share the LaBVIEW vis those you used for the daq?
It would be helpful for me to understand the data acquisition in cRIO.
(970 Views)
Hi kabino,
When you are "very new to cRIO" then you should take the Training resources to learn the LabVIEW RT/cRIO basics.
When you need example VIs/projects: just open the project explorer (File menu -> "New…") and select one of those example projects coming with LabVIEW-RT module! There are several example explaining "DAQ on cRIO"…
Btw. no need to hijack an 11 year old and totally unrelated thread, so I moved your message into your own thread!
(954 Views)
