Re: How to measure the Vpp, Vrms of a low frequency signal (<10Hz)
I am in need of help to set up a waveform using a Siglent 2042X.  I am new to this science and am looking for someone whom I can give the waveform info to and have them build the waveform or instruct me how to do so.  Since I'm not a scientist in this field please excuse my ignorance.  I am trying to create a sinusoidal am wave of 27.12Mhz that has an oscillatory amplitude that changes back and forth every 3 seconds from .01Hz to150Khz.  I believe there's a 50%modulation depth and at 11 m/s.  There's more info I can provide but that's the basic.  Any help would be greatly appreciated. I also have EasyWave if that helps.
Thank you for your time
(2,235 Views)
I recommend that you ask a Moderator (open your Message, click Options, and choose "Report to Moderator") to delete your Post.  Then return to the Forum, choose "New Message", and generate a New Message, with an appropriate Title (perhaps "Can someone help me with EasyWave?").  It is considered rude to "hijack" an old Post, particularly one that has little bearing on the question you want to ask (you are not measuring low frequency signals, you are trying to generate high frequency signals).
Bob Schor
(2,216 Views)
