Re: Import and export data arrays from labview to matlab
like suppose I have a very small examples of adding two variables, Take a=1, b=3 then c=a+b. How will I import this result on Labview.
Message 1 of 10
(3,375 Views)
Hi nitish,
are you still talking about Matlab?
Can you provide an example VI?
Are you using the Matlab script node?
(As your question now is completely different to that old thread you hijacked I moved it into its own thread.)
Message 2 of 10
(3,370 Views)
Yes I want to have real time communication of Matlab and LabView.
Like for example- I write a small program to draw a circle on Matlab and want to copy export only the figure on LabView
Message 3 of 10
(3,341 Views)
Hi nitish,
use network communication (like TCP or UDP based) to setup a data transfer between your Matlab tool and your LabVIEW VI…
Message 4 of 10
(3,339 Views)
Like I want to import this circle into Labview
Message 5 of 10
(3,337 Views)
And moreover how to use this network channels, as I am a new t this field I need help
Message 6 of 10
(3,333 Views)
Hi nitish,
LabVIEW comes with a huge example library. See the example finder to find example VIs on "network channels"…
Then send 3 values from Matlab to LabVIEW: "X center", "Y center", "radius"…
Message 7 of 10
(3,318 Views)
How do i send these values
Message 8 of 10
(3,315 Views)
Hi nitish,
that is a MATLAB question, and you should ask in a MATLAB forum...
Message 9 of 10
(3,306 Views)
Yes I but my question was that how do I send the three values as 'X center', 'Y center' , 'Radius' to LabView. could you please explain me about in a detailed way such that I can implement it.
Message 10 of 10
(3,303 Views)
