Re-Installation of Windows on Touch Panel Computer TPC-2206
I have NI Touch Panel Computer model TPC-2206 which had initially Windows Embedded Standard 7. But due to a mistake, window formatted. Now, i have downloaded the said windows and made a bootable DVD but DVD don't boots properly on the touch panel computer but boots properly on any other PC. Is there some other way to install window on Touch Panel Computer? Please help.
(2,429 Views)
I remember my days working with TPC-2206 and the only option there was to use Industrial Compact Flash cards as a system drive. I don't believe you can make it boot from DVD.
(2,323 Views)
II haven't used a TPC-2206 before but it looks like it has USB ports which means that you can probably boot from a bootable USB...unless the bios doesn't allow this.
(2,319 Views)
For sure it has USB ports but they should not be configurable as boot drives. You can access them from within OS.
(2,314 Views)
