Re: Is anyone experienced with Newport Electronics iServer-Microserver ethernet device?
I just bought Newport Electronics iServer-Microserver device to convert
serial to Ethernet and ran into the exact same "lockup" issue that
Buddy and Stephmon saw... We've been running into the same problem for
a week or two, so I finally decided to do some Google searching.
Can you guys (or anyone else) comment any further on the subject? How
reliable is actually UDP (i.e. does it lockup too)?
Do you guys suggest that I simply go buy another box, and if so, do you
have any recommendations?
Thanx in advance 😉
Jim Bretz
>From: Buddy Haun
>I have been testing the iServer devices with alot of the same issues everyone else has >been having. An additional item I noticed when stress testing the system is that if I used >TCP queries in a reasonable fast loop the iServer would lock up and require a reset >in 1-2 days. I seem to be having better luck using UDP and having the iServer broadcast. I >haven't been able to get the TCP broadcast to work correctly yet and don't really need >absolute timing anyway. Just thought I would toss that out in case anyone runs into >reliability problems they can't explain.
>Buddy Haun
>CLA
>From: Stephmon
>I sort of "intuited" that the device wouldn't be agreeable to being constantly queried... So, I >set it to "Continuous" and let it deliver at its own pace. I test the incoming string for its first >two characters (TA, TB, HA, HB, ...) and pass the resulting string to the appropriate chart, >or numeric indicator, through a number conversion and an If/Then that repeats the >previous non-zero value, until a new value comes along. My case logic is a tiny bit >flawed, in that it will never pass along 0.00F, but I never anticipate my lab, or the insides of >my devices, reaching that temp. Even so, it would pass 0.01F and -0.01F...
>Cheers,Stephen
(2,543 Views)
Hello Jim,
I'm not sure from your post how you are using this device, but National Instruments has several serial to ethernet converters.  They also let you connect Serial Instruments to an Ethernet Network.  Here is a link to one of the products.
https://www.ni.com/en-us/shop/category/gpib-serial-and-ethernet.html?productId=118842
I hope this helps.
Steven T.
(2,535 Views)
