Re: Linear fit
Hello Michael, Ihave a question about the Fitting Curve, is possible use the a polinomic fitting but condicioning the fit curve with initial and final conditions?
Thanks in advance.
Regards.
(3,145 Views)
Don't respond to an old thread with an unrelated question (your question has nothing to do with "linear fit"!). Please start a new discussion and explain exactly what you mean by your "conditions". The question does not make any sense.
(3,135 Views)
OK, the post was apparently moved to a new thread. (Subject needs to change too!)
For the question itself, see my response here.
(3,114 Views)
(3,109 Views)
