Re: Need Help w/Labview
Hey John, my initial project is to read a laser scattering data (in
millivolts) I got the boards set up and I experimented the analog inputs
with regular battery volatage and I got the program to work and graph the
data to a waveform chart. The main problem is that, i need a while loop for
termination. Appreciate your help. Take care Bobby
_______________________________________________________________
Get Free Email and Do More On The Web. Visit http://www.msn.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,296 Views)
Check out the Functions>>Structures>>While Loop. You can set the
condition and wire it to the stop, or you can use a boolean switch.
Beware, though, if you use the latter, wire it to an inverter and then
to the stop.
Hope this helps.
Jon A. Rinkenberger
Atmospheric Physics Research Laboratory
Physical Science Department
Embry-Riddle Aeronautical University
(3,296 Views)
