Re: Need help Implementing third party .net dll interface labview 2018
Hi Guys,
I have near no experience in implementing C# Dll.
I have only done once for a master IOLink but was very flat and easy.
This time this class is full of Interfaces and I don't have even a clue for where to start.
May you give me some advice?
Thankyou
(3,609 Views)
That doesn't look like a .net dll to me.
Based on the headers it's a PE dll, so you should be using CLFNs to interface with it.
PE dlls are quite different from .net dlls. They're a hole lot harder to grasp and will crash LV (a lot) if you're not doing it right.
You can try the Tools>Import>Shared library... wizard. But I wouldn't get my hopes up.
(3,587 Views)
I gave your post it's own thread, as it's not directly related to the thread you posted in.
(3,584 Views)
Sorry wiebe@CARYA,
the firm who did this, told me this assemlby was written in C# and based on .Netframework 4.8.1
How can I verify this assumption?
Greetings
(3,557 Views)
Sorry guys,
I think I'm doing a little bit of confusion: I have to version of the same library, or at least for the same purpose.
Here attached the C# version.
(3,526 Views)
@PincoG wrote:
Sorry wiebe@CARYA,
Greetings
Guess you found a way already.
If you try to open the dll with as a .net assembly, you'll get an error if it isn't a .net dll.
If you try to open the dll with as CLFN, you won\t see any exported functions if it isn't a PE dll.
The reverse isn't true, if you do get an error or see any exported functions, a lot could be wrong (wrong bitness, name mangling, missing dependencies).
(3,505 Views)
That's indeed a framework 4.8 .net assembly.
So what's the question?
To get (you) started we'd need to know what you're trying to do and optionally where you get stuck.
(3,499 Views)
