Re: Perspective Shift, Platform Strengthening
Dear All ...,
How can save a labview block diagram from labview image file . consider image file is received from RIO using Replication and deployment utility.
(3,224 Views)
Accepted by topic author Rahul711
An image file from the RAD tool is just a zip file containing all of the files on the cRIO.  What is on a cRIO is typically just compiled code, so I doubt you can get a block diagram from anything there.
Did you lose your code and are now trying to recover?
(3,192 Views)
