Re: RTD DaqmX Read
My question is not related to your question but just wanna ask if you can tell how to connect Ni9217 to RTD (wiring)?
(2,926 Views)
Hi swatej,
Since this is a fairly old thread, you may find an answer more quickly if you post a new thread with your question instead.  I would suggest creating a post in the Multifunction DAQ forum for assistance with the NI-9217.
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
Michael B.
Product Support Engineer
(2,914 Views)
Accepted by RavensFan
Hi swatej,
besides asking in a different board you might also read the manual that came with your NI9217 module.
It shows a schematic (page 13!) on how to connect a Pt100 sensor to your DAQ module!
(2,906 Views)
Manual does not specifies on how to connect the wires to the DAQ. But I figured out the if we just connect the RTD- to the COM using Jumper and do not connect the ground wire from RTD. we get the actual and correct readings. Thank you for the help though.
(2,875 Views)
Actually it does tell you how to connect on page 13 of the manual linked above exactly like Gerd says above.
I don't know what you mean by "Ground" wire from the RTD.  RTD's don't have ground wires.  Unless perhaps the RTD wiring is shielded.
(2,861 Views)
