Re: Seeing a hypervisor system in MAX
Hi
I have a NI PXIe - 8135, we run both "Windows 7 64bit" and "LabVIEW Real-Time" operating systems on PXI .
I want to run both operating systems simultaneously on PXI. So in NI tutorial found that NI Real-Time Hypervisor for Windows software enables to run simultaneously (http://www.ni.com/tutorial/11801/en/  )
In this link in section "1. Factory Preinstallation" said this software is preinstalled, but I can't find in this path [ Start >> Program Files >> National Instruments>NI Real-Time Hypervisor Manager]
Then I decided to install it and found that  NI Real-Time Hypervisor 3.0 for Window software supports Windows 7
but I can't found Hypervisor patch version 3.0 (http://www.ni.com/en-rs/support/downloads/software-products/download.hypervisor.html  )
Please help me how to run "windows 7" and "LabVIEW Real-Time" simultaneously on PXI?
Regards.
(2,555 Views)
Accepted by topic author tiba.shokatpour@gmail.com
Hey Tiba,
Just from the first link you posted, it seems you cannot use the hypervisor with Windows 7, as it states:
"NI Real-Time Hypervisor for Windows software enables you to run both Windows XP and LabVIEW Real-Time operating systems simultaneously...."
As you are running Windows 7 I do not believe it will be possible with the software you have found, and difficult if possible with other software (which I am unaware of).
As far as the NI Real Time Hypervisor goes, I cannot find a reference to it supporting Windows 7 - are you able to provide it?
Mitch
(2,520 Views)
hi
Actually, I found in the "PXI controllers with hypervisors" Topic, that  NI Hypervisor is not supported anymore and will not be published.
In addition, until now I can't find any solution to run windows 7 and LabView Real-Time simultaneously. Although Windows XP is very old, it seems that there is no other solution.
(2,504 Views)
