Re: Use listbox to select multiple channels and display on the graph
Hi Mr.X,
       I need some idea here, i was using 100 ton capacity load cell to test the cement slab here i was using usb 6211 to acquire the signal, if my user want to see a capacity in terms of kilo newton with respect to acquiring voltage, how to make a conversion factor, here?.
Strain gauge Load cell specification is
Load capacity - 100 ton
Rated output - 1.5mV/V
Excitation voltage - 10V DC
Compressive type
Message 21 of 22
(556 Views)
Hi Dinesh,
mind to attach a datasheet of your strain gauge?
Usually things clear up very fast when reading datasheet… 😄
Message 22 of 22
(545 Views)
