Re: Using Telnet
Ken wrote in message news:...
> Hello!
> I need to remote control some lab equipment from my office using Telnet.
> Does anyone know if there is a Telnet VI in LabVIEW 6? If not then how
> should I do it?
> I know that there is a TCP/IP function in LabVIEW, and I'm wondering if
that
> could solve the problem.
> Thanks,
> Ken.
Message 1 of 8
(4,461 Views)
hi Ken,
I think the tcp/ip vi is the stuff you are in need of. You need to set the
IP of your host computer, then set up some commands which you are going to
use. That's all, imho.
Fan
news:dfIc6.20225$_8.556531@news1.rdc1.bc.home.com...
> "Ken" wrote in message news:...
> > Hello!
> > should I do it?
> that
> > Thanks,
> > Ken.
Message 2 of 8
(4,461 Views)
internet developers toolkit contain telnet VI's, but you can also do it
yourself implementing rfc 764.
hope that helps
chris
> > Hello!
> > should I do it?
> that
> > Thanks,
> > Ken.
Message 3 of 8
(4,461 Views)
Sorry what's rfc 764?
"Christian Harböck" wrote in message
news:3A754E2C.E830227E@in.tum.de...
> Hi,
> hope that helps
> chris
> > > Hello!
Telnet.
> > > should I do it?
if
> > that
> > > Thanks,
> > > Ken.
Message 4 of 8
(4,461 Views)
Hallo Ken,
RFC stands for request for comments. These are documents publish from
IETF. RFC 764 describes the telnet protokoll (the command structur and
so on). You can find it e.g. under
http://www.landfield.com/rfcs/rfc764.html. If you just have to run a few
commands it maybe will be easier to run a telnet session and look at it
using a network sniffer (e.g. tcpdump).
Hope that helps
chris
> > Hi,
> > hope that helps
> > chris
> > Ken wrote:
> > > "Ken" m> wrote in message news:...
> > > > Hello!
> Telnet.
> > > > should I do it?
> if
> > > that
> > > > Thanks,
> > > > Ken.
(o o)
(O)
# mailto: harboeck@in.tum.de
# www: www.christian-harboeck.de
# phone: (089) 323 21 21
Message 8 of 8
(4,447 Views)
You can use telnet using TCPIP routines native to LabVIEW. You have to
use the TELNET specification, and use TCPIP port 110.
Also You can use the internet toolkit that is available for LabVIEW 6i
In article ,
> > Hello!
Telnet.
how
> > should I do it?
wondering if
> that
> > Thanks,
> > Ken.
Sent via Deja.com
http://www.deja.com/
Message 5 of 8
(4,461 Views)
Right... I just figured out from National Instruments' website that I could
have used the Internet Toolkit. I'm using LabVIEW 6i, but that toolkit is
nowhere to be found... any ideas? Do I need to download it?
wrote in message news:95569v$v4i$1@nnrp1.deja.com...
> In article ,
> > > Hello!
> Telnet.
> > > Does anyo
> how
> > > should I do it?
> wondering if
> > that
> > > Thanks,
> > > Ken.
> Sent via Deja.com
Message 6 of 8
(4,457 Views)
Ken,
The Internet Toolkit is an add on (software) product. National part number
is 777343-01 (Win 2000/NT/9x). Also available for Mac and Sun with
different part numbers. Cost is $495.
Jim
news:Id1e6.50341$_8.1488993@news1.rdc1.bc.home.com...
could
> wrote in message
> > In article ,
> > > > Hello!
> > Telnet.
> > how
> > > > should I do it?
> > wondering if
> > > that
> > > > Thanks,
> > > > Ken.
> > Sent via Deja.com
Message 7 of 8
(4,450 Views)
