Re: cRIO 9075
Hi guys,
I am currently working on a project which i use cRIO 9064 as my PMU. Also, i am using op4510(opal RT) simulator to simulate my power system model. My simulator provides +-16V output voltage, and 15 mA(max) output current. Since I don't want to use current/voltage amplifier which is needed to use NI 9225 and NI 9227 analog voltage and current inputs respectively, i would like to use another analog input modules except both of these modules(NI 9225, NI 9227) for smaller measurement range. I would appreciate if you could give me some suggestions.
Thanks in advance.
Şamil
(3,015 Views)
Hi guys,
Thanks in advance.
Şamil
(3,012 Views)
Accepted by topic author samil_07
Hi samil,
why do you post that question twice - in two old threads unrelated to your problem?
And why don't you call your local NI sales team for recommendations on needed modules?
(3,006 Views)
Well, i did it unintentionally, sorry. Thanks for the reply 🙂
(2,974 Views)
