Re: cluster to 1D array of clusters?
I have tried to insert build array function, the funny thing is that source and sink is the same type but LabVIEW doesn't allow me to connect the wire between them, wondering why is that?snipping shot.png
(2,186 Views)
Hi AIEXINUK,
you are creating an array of cluster of 2 strings: What do you expect the XYGraph to do with those strings???
Why do you try this at all?
(2,179 Views)
This probably makes a lot of sense if you come from Python, but LabVIEW does not automatically convert strings to numbers.
So, convert those strings to numbers...
(2,138 Views)
