Re: convert to labview 2015
Has anyone figured a way to use packet sniffing i.e. setting the NIC into promiscuous mode and reading the packets in 64bit LV?
It works for me in 32 bit but our entire architecture is based on 64 as we need to process large amounts of data (raw camera images).
(2,245 Views)
I assume you use the winpcap shared library wrapper that is posted elsewhere. The solution is to get the source code for that shared library wrapper and recompile it as 64-bit DLL. If you use a different solution, please elaborate.
Rolf Kalbermatter  My Blog
(2,213 Views)
One of my colleagues managed to compile the dll for 64. I've attached it for anyone else looking for it 🙂 I tested with LV2018 x64
(2,188 Views)
