Re: event structure and radio buttons
I'm quite interesting about that topic. In my case I have 2 groups of Radio button but I have to show some graphics depending on which Radio Button is tagged. I tried to do with AND port but it doesn't show anything. Here I have a Spectral analysis but it has two possibility. It would be in Spectrum of Amplitude and Spectrum of Phase. So I have even a third opcion where I show two waveform graphs and again depends on Radio Buttons combinations.
If you want I can show my code.
(3,887 Views)
share actual code instead of image.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,865 Views)
Yes, please do.
(The front panel is irrelevant. A bitwise AND would make no sense. Use a value changed event assigned for both controls, then combine the two values)
(3,836 Views)
