Re: function generator
I am sorry for posting at here because I don't know how to start a new message. I am so sorry.
May I ask a question regarding labview + function generator + myrio?
my question is, how can we know that myrio read a signal from function gen? cause I have already connected myrio port (A/AI0 pin 3) with a waveform chart but it didnt read the signal from function gen. It is because the signal that displayed on waveform chart same when i connect and disconnect myrio with fnction gen.
Sorry again for posting at here. Thanks for allowed me posting here.
(3,617 Views)
To post a new message, just click the NEW MESSAGE button that is below the announcements and above the list of threads on the LabVIEW forum.
However, I've gone ahead and moved your message to a new thread.
(3,591 Views)
If you change the waveform in the function generator, does the waveform chart change as well (that is the simple check)?  If you want help figuring out your issue, you need to supply your code.  Otherwise we is just shooting in the dark.
(3,533 Views)
