Re: need help with Keithley 2000/2400 labview programing
Sorry if this apears twice; Made an error. (HPV is from HP, not from
Keithley....)
Programming Keithley triggers is a bit tricky. On the other hand, it does
provide a lot of flexibility.
Keithley, in my experience, can and will assist on LV problems. Also, on
there page there are solutions (basic, C, HPV, but also LV) to various
problems.
Also, the problem looks like a configuration error, not a LV problem. In my
experience, Keithley will put a lot of effort in helping to find the best
solution. If it is not a LV problem, pleace descibe the setup more.
Wiebe Walstra.
AIR technical Automation
www.air.nl
"Motti F" wrote in message
news:959e15$7be$1@news.netv
ision.net.il...
hello
I'm using the keithley 2400 multimeter and the 2000 and I'm having
great difficulty writing them labview programs.
I'm using labview6 ,GPIB .
I wrote a sweep program that runs v,triggers the 2000 that measure other
parameters and the combination doesn't work.
if any body have a configuration program for either of the instruments it
will
be a great help.
thanks
motti
Message 1 of 1
(2,516 Views)
