Re: polymorphic subVI is broken
see this i am also getting the same problem.
(4,071 Views)
Hi sssptsc,
why do you hijack totally unrelated, 10 years old threads instead of opening your own one? ( I did this for you…)
What is the problem with your VI? I can run it without problems…
Why did you attach to a thread about "broken polymorphic VIs"?
Which "same" problem do you get?
(4,061 Views)
yes it is running but i am getting an overlap between top and bottom switches,that's why i asked for you to help me.But i don't know what you want to say.
(4,016 Views)
Hi 3s,
yes it is running
So it is working exactly like you have it programmed to work?
There are no "switches" except the stop button in your VI…
Which "switches" are you talking about?
Where did you ask so?
All you said was "I'm getting the same problem" - even when you (seem to) have a very different problem from that old thread you posted in…
(4,007 Views)
Attempted answer from a wild guess of an interpretation: Set the Sample property to 100 (instead of the current 1) in the signal generators.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,001 Views)
