Re: sbRIO 9607
Hello! I've a question regarding sbrio installation!
I've installed sbrio but the sbrio toolkit doesn't appear anywhere. Am I missing something?
LV doesn't show the sbrio in creating a project. Please tell me how to solve this issue
(2,567 Views)
You should install a version of the  NI CompactRIO DeviceDriver that is compatible with your LabVIEW version.
You should install the LabVIEW Real-Time module.
And you need at least LabVIEW 2015. (cf. http://www.ni.com/pdf/manuals/375277a.pdf)
Greetings, Jens
Kudos are welcome...
(2,554 Views)
