Re: usb 6008 suport PWM????
Hello, I have a same problem like you. You already solve your concern but I am struggling with this problem. I am using usb 6001 and bipolar stepper motor. Can you share the PWM VI example? I am wondering usb 6001 can use for PWM as well.
(2,787 Views)
Hi Kevin,
why did you hijack an old, but totally unrelated thread?
You are using different hardware…
- Did you read the spec sheet of the USB6001? It only supports "static DIO": no waveform generation on DO lines…
- LabVIEW/DAQmx comes with a huge library of example VIs: did you search for suitable examples in the example finder?
(2,783 Views)
