11-12-2011 11:57 PM
i am attaching the schematic, so you can understand the arrangement. As i start measurement initially i got values near 80mOhm then suddenly it goes above 100mOhm then slowly it reaches around 130 mOhm then it vary back & forth between 130 to 140mOhm. I m measuring the resistance of a fuse box wire.
(50mV & .1mA is the open circuit voltage & short circuit current which i set in the SMU )
11-13-2011 12:38 AM
