Rea File
Can anyone help me to read the attached file in labview (file.raw). Most probably its a Binary File. The file should give the same results as the attached *.txt file as an example
(3,087 Views)
Hi Anirban,
use this as a starter:
For all that other information you may need to read the manual of the software producing those RAW files!
(3,074 Views)
Can you say the name of the program, it is often easier to google information than try all possible options. Also if I am hacking proprietary format I would like to know it =).
(3,070 Views)
