Read 2182A by triggering through 6221
Message 41 of 48
(2,470 Views)
Hi Eyuzuak,
In order to use the Instrument I/O assistant you need to have NI VISA and NI 488.2 intalled.
The link below provides additional information on the procedure to follow if you are not able to access the Instruments I/O Assistant.
http://digital.ni.com/public.nsf/allkb/DC808866AF7D5C0986256FCE006E9BAB
Regards
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
Message 42 of 48
(2,465 Views)
Have you got any *.vi program or trees for using
2182A by triggering through 6221.
Thanks.
Message 43 of 48
(2,450 Views)
I am communicating with a 6221 from my PC via Ethernet  cable and I have a 2182 Nanovoltmeter connected via RS-232 and trigger link cable to 6221.
But I am not getting any data when I send command.
I also used drivers fro keithley. I am able to set current on 6221 using these drivers but not able to read voltage on nanovoltmeter.
Thanks for any support.
Rupali
Message 44 of 48
(2,276 Views)
I am having some trouble connecting a 2182A nanovoltmeter to a 6221 current source using the pc control system. The current source connection with the ethernet works fine, but the nanovoltmeter encounters a -113 error (Unidentified Header). The RS-232 and the trigger link cable are connected as indicated and the RS-232 is on. I can't find what's the problem.
Following settings on  Model 2182A are done
for RS-232 with
19,2k BAUD
FLOW = NONE
TC TERM = CR
Any example vi is more helpful for me.
Thanks.
Rupali
Message 45 of 48
(2,266 Views)
Since you are using third party instruments and third party drivers, the best place to look for a shipping example is with Keithley. You may also try opening a new forum post to get more attention from the community. Thanks!
Message 46 of 48
(2,249 Views)
I have the same problem too , error -222 parameter out of range. I can not control my source using KI6220.vi. Anybody help ?
Message 47 of 48
(2,104 Views)
Hey Oulll,
This thread is from 2008 and likely will not be actively viewed! I would recommend making a new forum post with your issue to get better visibility.
--Hunter
Hunter D.
Message 48 of 48
(2,088 Views)
