Read ADTF file in LabVIEW
I'm developing an application, where I need to read data from ADTF format files.
I have found a DataPlugin for ADTF files (ADTF_DAT), but it can be used only in host application, while I'm going to read files on RT controller.
Does anybody knows if somehow Storage/DataPlugin VIs can be used on RT, or where I can find description of the ADTF file format, to try to develop the file read VIs myself?
Arev
CTO | RAFA Solutions
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
(5,123 Views)
@arevh wrote:
Does anybody know where I can find description of the ADTF file format, to try to develop the file read VIs myself?
When I did a Web search for ATDF Format, I found this:
ASCII Test Data Format (ATDF) Reference - SourceForge
This specification refers to the Standard Test Data Format (STDF) V4 Specification
Bob Schor
(5,096 Views)
Hi Bob,
Thank you for your research. But actually I was looking for some information regarding ADTF format. It differs quite from ATDF format.
ADTF is an Automotive Data and Time-Triggered Framework.
Arev
(5,081 Views)
Oops (or maybe I should say Poos).  So I presume you also saw the ADTF "Toolbox" (which seems to have at least a Matlab "hook") by Elektrobit.  There's not a lot of info out there on the web, it seems ...
Bob Schor
(5,065 Views)
Yes. That's why I tried to ask in the forum, hoping somebody had dealt with ADTF format files.
Arev
(5,062 Views)
