Read BMP File Requires Absolute Path
I noticed something today regarding the Graphics Formats, Read JPG File, Read PNG File and Read BMP File vi's. It seems that when reading a JPG or PNG file, a relative path is OK, but when reading a BMP file, an absolute path is required. When the path only contains the filename, it returns:
    Error 1430
    "Open/Create/Replace File in Read BMP File Data.vi->Read BMP File.vi->ReadImageFileTest.vi"
I tried a simple test that uses either the relative or absolute path, trying to read 3 different files in the same directory as the VI. Only the Read BMP File errors. Of course, the simple work around is to always use the full pathname to a file. Is this only on my system? Is this a known bug or feature or expected behavior?
I'm using LabVIEW 8.2 on Windows XP.
Thanks!
B-)
Message Edited by LabViewGuruWannabe on 11-05-2007 11:06 PM
(3,832 Views)
Missed this on the first post:
Message Edited by LabViewGuruWannabe on 11-05-2007 11:10 PM
(3,826 Views)
Hi LabVIEWGuruWannabe,
This has been previously reported to R&D (CAR ID #48OD9NOR) for further investigation.  It looks like in the meantime you will have to go ahead and provide the absolute path.  I hope this isn't too much of an inconvenience.  Thanks for the feedback!
Have a great day!
Jason W.
(3,786 Views)
Thanks, Jason. That's good news.
B-)
(3,773 Views)
