Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Read DCD on serial itf ?
Pierre Lambert
Member
11-16-2002
02:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Does anybody know how to read DCD on a serial interface using labview and
appropriate serial VIs ?
I'm using both NI serial PCI hardware and PC standard
Thanks for your help
0
Kudos
Message
1
of 3
(3,295 Views)
Reply
Re: Read DCD on serial itf ?
Chris_Rake
NI Employee (retired)
11-16-2002
09:01 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can read the state of the modem lines using VISA and the property node.
0
Kudos
Message
2
of 3
(3,295 Views)
Reply
Dennis_Knutson
Knight of NI
11-16-2002
09:04 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If by appropriate serial VIs, you mean VISA, then use a VISA property node. The property is Mdoem Line Settings>Line DCD State. I don't think it's available with the old serial driver.
0
Kudos
Message
3
of 3
(3,295 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
