Read Delimited Spreadsheet - Error 7
I am attempting to read in data from a .csv, something very basic - containing only numbers. I have been using a resolver simulator project downloaded from the NI site. So, when I try to simply load in the data, I get Error 7, "Open File+.vi:Open File". If I create a new project from scratch and implement the exact same thing, it has no issue.
(4,289 Views)
Accepted by topic author npadilla
Error 7 is defines as File not found!  The problem has nothing to do with the format of the file.
Things to check:
  1. Is the filename spelled correctly?
  2. Is the extension spelled correctly?
  3. Is the full path correct?  Try browsing for the file.
  4. Is the file still open in Excel?
  5. Is the file locked by another file function in LV?
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(4,268 Views)
Upon doing further research I realized that I had incorrectly assumed the cRIO would have access to my PC's local storage. To resolve that issue, I've opted to send data through a VI stored on the PC with share-variables.
(4,238 Views)
