Read Excel File and Write to FIFO
Can you share screenshots of your labview block diagrams
Message 11 of 12
(568 Views)
Here you mean you can have host Vi FIFO SIZE as big as posiible.I have huge data upto 5mb.so what size of FIFO I should use.I think maximum host FIFO size is 1048581.So if I have data more than that I should keep this maximum size for FIFO?
Just to clarify I should pass all the data at the same time to HOST FIFO?and FPGA FIFO how to receive data one-by one to process it later on FPGA ??
I have attached images of the progress I have made.
My main problem here is I want data from computer(HOst Vi) to be used by FPGA for processing.Hence I nedd to communiacate data from host PVI to FPGA VI after this data gets to FPGA I want to do some operations on this data and get output.
Message 12 of 12
(565 Views)
