Read HTML code from HTTPS url
Hello everyone, is it possible to read the HTML content code of a web page that has an url in HTTPS without using IWEBBROWSER2 ??
For example with ActiveX .NET?
Thank you
Message 1 of 12
(8,104 Views)
Use the HTTP client found in the  "Data Communication" -> "Protocols" palette.
Message 2 of 12
(8,062 Views)
You'd probably need a lot more code (from the Security palette) then that to set up the SSL connection. AFAIK, SSL+HTTP=HTTPS.
I've used stunnel in the past, so the problem doesn't need to be solved in LabVIEW anymore. Stunnel will route the shhtp data to http data.
Message 3 of 12
(8,050 Views)
Worked fine for me visiting the HTTPS of amazon.com. Body contained the full HTML/Javacript.
The header did include the HSTS request, but at that point I already had the body.
If you try to visit the HTTP version, it only returns a 301 permanent redirect header (pointing to the HTTPS version) and no Body.
0xDEAD
Message 4 of 12
(8,035 Views)
Hi deceased, I tried with the example above (http post) but it does not work, the html code returned in the body is encoded and therefore illegible.
 url : https://www.amazon.com
Message 5 of 12
(8,025 Views)
@wiebe@CARYA
OK, thanks for the reply :), would you have an example code?
Message 6 of 12
(8,021 Views)
@NicolaRE77 wrote:
@wiebe@CARYA
Not really. I actually have no idea how that would work from LabVIEW. I saw that the HTTP interface has SSL options, but I have no idea what should be wired to what VI...
When I used stunnel, my application actually was the HTTP server. I used .NET for that, and figured I'd better outsource the SSL part.
Message 7 of 12
(8,004 Views)
ok, I think there is this, but where do I find all these certificates and api key?
Is not the client_certificate alone enough?
Message 8 of 12
(7,993 Views)
Is it possible that no one has exploited an HTTP + SSL communication? SOS
Message 9 of 12
(7,945 Views)
Nope. The HTTP VIs do unlike what their name might suggest, also support the HTTPS protocol. As long as you try to connect to a HTTPS server with valid certificate signed by one of the well known certification authorities, they should simply work. If you try to access a server with self signed certificate you have to setup your own certification store with the correct certificate which the HTTP VIs only expose a very simple and not always workable method for.
Rolf Kalbermatter  My Blog
Message 10 of 12
(7,935 Views)
