Read LDF with XNET
Hello All,
I'm trying to open LDF file (2.0 or 2.1) in Labview to get all signals. According Google, this can be done by XNET.
I tried with property node, but it gives only cluster.
Can someone explain how to do this?
Thanks a lot.
(2,582 Views)
Sorry, this is solved 🙂
Is there a way to encode signals automatically using LDF?
(2,580 Views)
What do you mean by this?  Are you asking about ways to make a database programmatically?  If so the Example Finder (Help >> Find Examples) has a couple of examples on making an XNet database.  This can then be saved, and I even think exported back into an LDF.
(2,515 Views)
fundamentals-of-using-the-ni-xnet-api-for-labview
LV Project >> Right-click on My Computer >> New >> NI-XNET Session >> ...
Then use the sessions in your LV code.
Is this what you would like to do?
(2,502 Views)
