Read Measurement from Lecroy SDA
Hi Everyone,
I have a problem with a VI (Both screenshots for the same VI):
1- In the first Screenshot, you will see the VI where It reads the measurement with VBS string before the required value
2-  In the second Screenshot, you will see the VI where It reads the measurement without VBS string before the required value
I have to modify the VI every time I use it from case 1 to case 2, It's being changed automatically and it is wasting my time. Any solution to have Permanent case either 1 or 2? The attached Front panel is for case 2
Thank you,
Ahmed
Message 1 of 1
(2,098 Views)
