Read Memory Register from PCI-Card (without divice driver)
I want to program a vi in Labview. This vi should send and receive data with a PCI-Card. I can send data with the "Out Port.vi" when i write on the output register (adress 0xD100) of the PCI-Card. That´s OK.
But the receive is the problem. The receive data saved in the memory range on the PCI-card (adress 0xEC000000). When i use the "In Port.vi" it dose not work with this adress. I think the "In Port.vi" don´t supports the 32-bit adress.
It exists no device driver for the PCI-Card.
I use Windows XP
How can i read from this Memory range on the PCI-card?
(3,255 Views)
A search of the NI forums returned these two threads that may be of interest/help:
(3,239 Views)
You can also use VISA.
(3,237 Views)
