Read Multiple Files
Is it possible to open and read from multiple files.  Right now my program is setup to read one file.  I used the Read characters from file vi.  This works like a charm, but i want to give the user the option of selecting multiple files.  Any help anybody.
(3,882 Views)
Just do it in a loop.  You will probably need to have the UI part of things outside of the loop, but it should be about that simple.
Hope that this helps,
Bob Young
(3,874 Views)
Here is a simple example of using a loop to prompt the user for a file.  The file is opened, read, displayed, and then closed.  If the user presses the cancel button in the file dialog box, the loop exits.
- tbob
Inventor of the WORM Global
(3,869 Views)
I appreciate your help guys, but i already have it setup in a loop.  I was just hoping there was a way to select more than one file at a time.  Thanks.
(3,867 Views)
Some time ago I downloaded the attached library from somewhere. I don't remember where and when, but I think it will do what you're looking for ...
... at least if you're using Windows. It uses calls to Windows DLLs.
Regards
Arno
(3,864 Views)
Thanks Arno,  the vi's you provided will work.  Just have to modified them a bit, but should work.  Thanks again
(3,842 Views)
