Read Multiple Tags Status code?
Hi, I am using the Read Multiple Tags VIs to read item data and status from the DSCEngine. I can not find any documentation on the Status codes that are delivered from these VIs. Help appreciated. Thanks.
(2,666 Views)
you can use the Get Tag Status Info.vi from the DSC System function folder to resolve the status to a more descriptive error/warning.
The general description on the status is located in the VI-Based Server Development Toolkit Reference Manual (LabVIEW\manuals\VISerer.pdf) in Chapter 2 on page 2-14.
Hope this helps
Roland
(2,666 Views)
