Read Serial Data
Dear All,
I am reading data from serial port which the VISA read function stores in a string buffer.
 is dere any way by which i can store the data in a string array as i want to access the data in bytes separately??
Ritesh
Message 1 of 13
(5,335 Views)
You can acess each character seperately if you wire the string into a for loop and enable indexing.
Message 2 of 13
(5,334 Views)
Hi drewsky!
This solution was new for me, so I tried to wire a string into a for-loop, but I can't enable indexing (top of image). Can you specify what you mean? Do you mean a solution as showed on the bottom of the image??
Greetings,
Christian
Message Edited by cschneider on 08-09-2008 04:40 PM
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
Message 3 of 13
(5,322 Views)
Yeah that's what I meant.  I don't have LV on this comp, so I didn't try it ahead of time. Smiley Sad
Will that work for you?
Message 4 of 13
(5,299 Views)
Is this what want to do ?
Message 5 of 13
(5,281 Views)
ritesh024,
You can enable indexing into and out of a FOR LOOP by right clicking on the input/output box at the boundary of the FOR LOOP.  In your case in the top FOR LOOP the pink incoming box.  Regards,  -SS
Message 6 of 13
(5,254 Views)
that's what I thought too, but I just tried it, and it won't allow it.  The software I am using right now is beta, so I could be wrong...  I'll double check at the office tomorrow...
Message 7 of 13
(5,248 Views)
LabVIEW 64-bit beta?  -SS
Message 8 of 13
(5,245 Views)
yeah
Message 9 of 13
(5,243 Views)
Thanks alot guys for your help.
That for loop solution works gr8.
and one more thing .. you cant do auto indexing for a string in for loop. you can only do it for an array..
so, u need to break the string into substrings for storing a string into array ..
Ritesh
Message 10 of 13
(5,213 Views)
