Read Serial port @100 us
Hi guys,
I'd like to know if Labview can read serial port @ 100 microseconds?
Is it necessary any specific HW for  that? What HW can I use to read at that rate?
Regards
Kito
(3,229 Views)
A baud rate 0f 10000 is not standard so you would need something like the PCI-8432/2 which allows you to select any baud rate.
(3,196 Views)
But If I use Labview (not Real Time), Can I receive data at 100 microseconds and plot it using that board you've mentioned?
(3,180 Views)
If the data is sent at that baud rate, then yes. If tou wish to read a serial instrument every 100 us, then no - you don't have that kind of tming control on windows.
(3,158 Views)
Take 5-10 minutes and explain your problem much better. Like this. I have an instrument xyz. This instrument use a ZZZ communication protocol, over a YYY link. In my Labview program I want to achieve this XXX. This is what I have done so far.
Remember good questions draw good answers. Smiley Indifferent
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,144 Views)
