Read TDMS buffer size
Is there a way to read the size of the buffer for a TDMS stream so that you can determine whether there are any problems writing the data to disk?
Chris
(3,235 Views)
Read this about the default settings and your options to modify them.
tdms_set_properties
hope it helps
Christian
(3,081 Views)
Hi Christian,
Thanks for the reply.
I have been through all these previously and i don't think there is a property for what i want to do.
I have been in touch with NI and i have had conformation that accessing the buffer of the TDMS stream isn't possible.
Thanks again.
Regards
Chris
(3,040 Views)
