Read Variable using DSP Test Integration Toolkit
     I am using LabVIEW DSP Integration tool kit to get some variable values from DSP code during run time. I am able to get symbol values if I am specifying symbol name as string input. I am expecting to read from LabVIEW code  some global variable values, if i am giving variable name as string. I could not find any help over the same.
Any  help to resolve the problem is highly appreciated.
Thanks in advance.
Vijay
Message Edited by 12345qwertt on 08-05-2008 03:20 PM
(3,047 Views)
Also RTDX communication is not enabled.
(3,036 Views)
Hi 12345qwertt,
This toolkit is no longer officially supported by NI, but you can download the VIs that were included in this toolkit, and there are still resources available on NI.com.
NI LabVIEW DSP Test Integration Toolkit
LabVIEW DSP Test Integration Toolkit for TI DSP Manual
LabVIEW DSP Test Integration Toolkit Video Demonstration
I'm having trouble identifying the question in your post.  Would you please elaborate?
(3,021 Views)
