Read/Write ASM340 leak tester with LabVIEW over RS232
Hi Community members,
I have limited experience with LabVIEW but enough to use the QMH to build applications for basic control + logging. I would like to read/write a leak tester from pfieffer vacuum with LabVIEW.
I Would like to start the leak test procedure and log the leak rate of the leak tester using it's RS232 port.
This I think should be possible with the advanced mode and long commands.
What I do not understand is how to translate the commands from attached document to strings that should be send over RS232.
Any help is welcome.
Twan
(2,198 Views)
This is a good starting point - https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
Santhosh
Soliton Technologies
(2,197 Views)
have you got a program to read data from ASM 340? if yes, can you please share it here?
(1,315 Views)
