Read/Write to FPGA help
Hello, I am using NI Digital Electronics FPGA Board and LabVIEW 2009 software. I made a simple vi that uses the Memory Write method to write a single data on the memory of the FPGA. However, whenever I use the Memory Read method, the compilation aborts past halfway and shows this message:
This application has requested the Runtime to terminate it an unusual way
Please contact the application's support team for more information.
ERROR:Xflow - Program par returned error code 3. Aborting flow execution ...
On the other hand, I'm quite a newbie in using the FPGA Memory Read/Write method, and it seems that example VIs on the internet regarding this is scarce. I suppose that this problem arose because something is wrong with my use of Memory Read/Write method... What can you suggest?
Paul Rigor
(2,680 Views)
Hi Paul,
The only other time I've seen this error it happened because one of the vi's that were being used was corrupted.  I would suggest trying to copy and paste all your code into a new vi and save it.
This should resolve your error.
Let me know how this turns out,
Dave T.
FlexRIO & R-Series Product Support Engineer
(2,663 Views)
Hi Dave, I've already fixed the problem by implementing the Memory as a look-up table rather than a block memory.. anyway thanks for your help 🙂
(2,647 Views)
