Read analog From modbus
Hello all ,
I am getting the error when reading the analog values from the controller.  (16 bit )
when I am checking the room temperature the error message is throwing.
The number of inputs I gave as 1 for reading room temperature. The real requirement is to measure 8 temperature. data.
Thanx in advance
(2,497 Views)
Looks like the "Starting Address" value (set to 0 in your VI) needs to be something else. I don't have the Modbus VI, so I can't check the context help, but I'd guess if you replace the 0 with either 30001 or 30051 you might have better luck.
(2,481 Views)
