Read and Write Simultaneously
Hey..
Does anyone know if you can open a file, write to it and while it is still
open then
read what you just wrote, then write more info to it, and so on....
Cheers.
(3,043 Views)
yes, you can do this in LabVIEW
You need to use the open, write, read, and close vi's
The read / write vi's use bytestreams so you may need to do a little more
formatting with your
data than with the "simple" file I/O vi's
amie wrote in message <387a7372@newsgroups.ni.com>...
>Hey..
>open then
>Cheers.
(3,043 Views)
