Read and write simultaneously to same file from two VIs, or 'open when available?'
I have two VIs that both access the same text file asynchronously, one continuously reading and one writing. Every so often one or the other process fails because the file is currently locked. Is there a way to:
1. Tell Labview to open for read in such a way that it does not prevent writing by another program?
2. Have LV wait for the lock to clear and then open (without me making some sort of while loop)?
3. Something else?
Message 1 of 24
(7,094 Views)
a QMH (Queued Message Handler) would be the way to fix your problem.
Writer sends requests to write and the data to write into the queue.  Reader sends requests to receive file data and a ref to the Queue he is listening on.
Cakewalk
Message 2 of 24
(7,078 Views)
I think though, that this won't work because they are separate memory spaces (compiled VI into exe). Or is there a way to share a queue between them?
Message 3 of 24
(7,059 Views)
You can wrap-up an Action Engine and use VI Server to call functions in one application with another application.
Allison claimed she posted an example in this thread.
Ben
Message 4 of 24
(7,053 Views)
I am assuming you have tried opening the file with the access level set to read only, and the problem still occurs?
Message 5 of 24
(7,046 Views)
Here is a network queue. It acts just like a normal queue but transports data over a TCP connection so you can use the queue to communicate between two applications.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 24
(7,044 Views)
I am using the read/write from spreadsheet. Is there a way to make this read only when I read? Or, more generally if I am using these two together on the same file is there a way to make them not step on eachother's toes?
Message 7 of 24
(7,005 Views)
Thank's for this idea. I might try this this week and see where I get.
Message 8 of 24
(7,004 Views)
Hi, can you save this network queue as 2016? Our system is locked into that version until we have a lot of down time to regression test everything with a newer version. Thanks!
Message 9 of 24
(6,979 Views)
Here is a LV 2015 version. I happened to have a copy on my PC.
Mark Yedinak
LabVIEW Champion
Message 10 of 24
(6,974 Views)
