Read array data
I have a numeric control and an array. I want read (by index array) from index 0 to index= number in a numeric control.
I can't have a loop because i want create a subvi with the block diagram.
How can I do this?
Thanks.
(5,520 Views)
You'll need to be a bit clearer.
That's clear.
That's not clear. You want to read an array subset from 0 to the number in a control? So, read the control value, and use array subset to get the subset from 0 to the number.
This doesn't make much sense either. You can use a loop in a sub VI.
(5,512 Views)
I agree with Wiebe (I do that a lot!) that I also don't understand why you are having trouble.  I think you probably have some code that illustrates what you are trying to do (and, possibly, trying to put into a sub-VI), but there are a number of "unclarities" (I don't think that is really a word in English) in your Post that would be "clarified" (now, that is an English word) by your posting a VI that shows what you are trying to do.  Questions in particular:  What do you mean by "read (by index array)" -- is this File I/O, DAQmx Read, or something else?  What do you mean by "create a subvi with the block diagram" -- is this using "Create SubVI" in the Edit menu?
Bob Schor
(5,459 Views)
Yes, i want to read an array from 0 to the number in a control, and i'm using a index array fuction, but, how i do that the fuction reads firstly 0 then 1 then 2 .... to five por example. (Imagine taht the numero control is 5)
It is possible to create a Sub.Vi with for loop inside?
(5,434 Views)
Hi cristina,
Yes!
Use an autoindexing FOR loop with your MAX value wired to the N input…
I strongly suggest to take the free learning stuff offered by NI to learn basic concepts of LabVIEW like autoindexing loops…
(5,426 Views)
Question remains: why? "Array Subset", "Delete From Array" and even "Split Array" and "Reshape Array" do that (use the first or second). No need for a loop.
And since you don't need a loop, you might not even need a Sub VI. Nothing necessary wrong with a single function in a Sub VI though...
There is nothing you can put in a VI that prevents it from using it as a Sub VI. At least nothing to be concerned about. Some things would be silly, but a for loop definitely is not.
Doing the (free) courses will help indeed.
Posting (a subset of) what you have might help too.
(5,421 Views)
If this is some course and the assignment is to get X numbers from an array, Array Subset is the tool.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,408 Views)
