Read back from Multivu to LabVIEW
I am planning to communicate Multivu from LabVIEW. I downloaded QD LabVIEW library. Using this library I am able to send commands to PPMS but unable to read back values from PPMS to LabVIEW. Please suggest workable solution for this issue.
(2,446 Views)
Hi suman,
Mind to supply explanations for all those abbrevations in your two sentences?
What have you tried and where are you stuck?
(2,443 Views)
This is the Quantum Design (QD) Physical Properties Measurement System (PPMS). I am trying to control temperature, pressure, chamber operations etc remotely from LabVIEW using LAN network. QD has provided a VI library. Using this library I am able to send commands to Multivu computer from my LabVIEW computer. However, I am unable to read data continuously from Multivu on my LabVIEW computer. I am looking for a solution to resolve this issue.
(2,433 Views)
We cannot offer suggestions without seeing what you are actually doing. How familiar are you with LabVIEW programming?
(2,365 Views)
