Read data from Excel via .Net interface
I'm currently developing an application with a .Net interface for Excel. I really don’t like to use the NI LV toolkit because of the legacy ActiveX interface. Writing to Excel works just fine, but reading from a spreadsheet fails at the point where I am trying to convert the values from the .Net reference to LV variant. Does anybody have a working solution for the problem?
I’ve attached my current status.
Message 1 of 11
(7,590 Views)
Accepted by topic author aptivo
This thread indicates that 2D-array is not handled by ".NET object to Variant", and proposes the solution of reading cell by cell.
Certified LabVIEW Architect
Message 2 of 11
(7,562 Views)
I like the EPPlus .NET DLL
https://github.com/JanKallman/EPPlus
You don't have need Excel to be installed !
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 3 of 11
(7,560 Views)
This is true. If using the workaround which is proposed, by reading cell by cell  with nested loops it is working perfectly.
Thanks a lot!
Message 4 of 11
(7,551 Views)
Do you have an example of using this Library in LabVIEW?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 5 of 11
(7,473 Views)
Is this library thread safe? In my use case it may occur that two excel files are created at the same time.
Message 6 of 11
(7,414 Views)
I found a link:
https://forums.ni.com/t5/LabVIEW/Create-spreadsheet-using-Open-XML-SDK-Net-with-Labview/td-p/3235208
I've just tried it and it is really easy to use.
Message 7 of 11
(7,405 Views)
Hey aptivo,
Thank you for reporting this, I filed a bug report with NI.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 8 of 11
(7,373 Views)
I've done this as well and I got a reply yesterday. It is filed under CAR 732638.
Message 9 of 11
(7,355 Views)
Hi everyone,
The above method is the only one working ok found by me so far. But for large files it takes too much to load them. I fell asleep near the computer for files with 10 000 rows ...
The next one, using Value2 property is still not working.
Has anyone else found a workaround for this matter?
Daniel
Message 10 of 11
(4,395 Views)
