Read data from RS232 (Serial) port
You don't have a manual and you only got emails with the command and response codes. You do have their software and from the sound of it, their software works.
If it was me, I would use some type of serial port sniffer and see what actual commands/responses are generated (including termination characters) with their "working" software to position the traverse. Otherwise, you and we would be just guessing.
Message 11 of 13
(1,530 Views)
Hi Arun,
They don't have a proper manual, or a software; they use a code they wrote in C, which in itself is not at all user-friendly, and very clunky. The response codes were obtained by directly emailing them about the hardware.
Ask them again - that's what I would do!
Can you (or "they") provide the C source code so any programmer could read how "they" send commands and how "they" receive the answer of the hardware? This would help too…
Message 12 of 13
(1,526 Views)
Accepted by topic author Aryce
UPDATE: I fixed it! Code's working now.
BytesAtPort was the right way to go after all. I had tried a second Read loop earlier which failed, but that was because I forgot to reset it. Anyway, thanks for your suggestions, GerdW. And jamiva, that was a great suggestion; I hadn't thought of that. Although it didn't tell me any more than what I knew about what the communication codes were, I was able to see how the delays worked, so thanks.
Message 13 of 13
(1,501 Views)
